deepakb
Cascading OSEDESE3
I need to have a logic to convert the more than 8 bits parallel data (say 12 bit or 14 bit) to single bit output using OSERDESE3 as I am using Zynq ultrascale plus device. In case of Zynq and 7 series device this was done by using the cascading option which was available through SHIFTOUT and SHIFTIN pins of OSERDESE2.
However these options are not available in OSERDESE3. So I would like to understand how this logic can be implemented. Please let me know if any documents or application notes are available for same.
Thank you in Advance.
DPK
pthakare
Hi @deepakb
This is already answered via SR to Deepak.
Higher serialization factor i.e  10:1 or 12:1 cannot be implemented directly  by OSERDESE3 as cascading functionality is not supported.
We don’t have readily available application note either ,
 10:8 and 12:8  gearbox FIFO you have to implemented  similar  to 7:4  in XAPP1315  with 8:1 serialization by OSERDESE3 for 10:1/12:1 serialization,
pthakare
Hi @deepakb
