simonlindberg
DC coupling mode ADC on ZCU111
I want to DC-couple the outputs from the ADC:s on the Zync UltraScale+ RFSoC ZCU111. For this I need the common voltage output (VCM) from the ADC which I have extracted from the plug-in board. However, I don't get the 1.2 V output which I expect. In ug583 it is stated that "The VCM output buffer is only enabled in DC coupled mode.", but I have not been able to figure out how to change from AC coupled mode to DC coupled mode. The only thing I have found is how to read out the current state using the XRFdc_GetLinkCoupling function. Does anyone know how to configure the ADC to work in DC coupled mode?
pthakare
@simonlindberg
There is no API to set the link coupling.  You need to set it in RF data converter IP
pthakare
@simonlindberg
klumsde
Hi @simonlindberg
You'll have to set this in the IP I think.
I don't think it makes sense to be able to switch between AC and DC coupled mode on the fly. Hence there is only a "Getter" for the Link Coupling mode in the driver API.
To enable the VCM output you need to set the link coupling to DC in the IP. link_coupling.JPG
simonlindberg
Thank you for the help.
