.@.@.v.@.@.
DRC 23-20 - IDELAYE3_cascade_crosses_byte_boundary
[DRC 23-20] Rule violation (PDCN-2708) IDELAYE3_cascade_crosses_byte_boundary - IDELAYE3 system_timer_1/u_system_timer_strobe_align/u_idelay/u_idelay_master participates in a delay cascade with IDELAYE3 system_timer_1/u_system_timer_strobe_align/u_idelay/u_idelay_slave_middle that crosses an IO Bitslice byte or bank boundary and cannot be routed properly.
I'm trying to use a cascade of 3 IDELAYE3 devices, and they're setup like in UG571 page 174 Figure 2-18 (Rev June 12, 2018), but even if I move the pin around I am getting this implementation error.
I am looking at the pin map of our device located at:
https://www.xilinx.com/support/packagefiles/usapackages/xcku115flvf1924pkg.txt
Below is the relevant cascade from the synthesis view; it looks correct to me, but maybe I'm too "close" to it.
Thanks for taking a look!
Tags (3)
pthakare
Hi .@.@.v.@.@.
In your implementation you have cascaded  IDELAYE3-IDELAYE3-IDELAYE3  in the chain . It should be IDELAYE3 -ODELAYE3-IDELAYE3.
other point to consider here
The delay elements can be cascaded up to the byte boundary in a downward direction, So make sure that you have at least one unused IOB below the IOB used for receiving Sync_strobe_in  input in the byte.
Reply if you have any queries, Give Kudos and Accepts as Solution
Reply if you have any queries, give kudos and accept as solution
pthakare
Hi .@.@.v.@.@.
.@.@.v.@.@.
You are 100% correct, thank you!
chenj15
I got same error message (ODELAYE3_cascade_crosses_byte_boundary)  and I do have cascaded  IDELAYE3-IDELAYE3-IDELAYE3  in the chain.
The detailed error message is
[DRC PDCN-2709] ODELAYE3_cascade_crosses_byte_boundary: ODELAYE3 JetCam_Test/Gen_Top_RX[3].GP5301_RX_Shift_Register/ODELAYE3_inst2 participates in a delay cascade with IDELAYE3 JetCam_Test/Gen_Top_RX[3].GP5301_RX_Shift_Register/IDELAYE3_inst3 that crosses an IO Bitslice byte or bank boundary and cannot be routed properly.
Jim
pthakare
Hi @chenj15
Can you please create an new thread ?  The older one is already answered and your issue seems to be little different
chenj15
Thanks for replay,
How to create a new thread? I never did one before.
Jim
pthakare
Hi @chenj15
Follow the below steps
