Does GTH TX work on RX recovered speed?
Can Ultrascale GTH TX work on RX recovered speed? Typically TX work with speed based on external reference clock but I have to
transmitt exactly same received data stream (that can have little difference like several ppm).
Re: Does GTH TX work on RX recovered speed?
In this type of use case, the recovered clock output from the GT is given as input to the external synthesizer for jitter cleanup. The output of this synthesizer is given as input to GT reference clock.
Hello @sergey_checkrygin,
Yes this is possible to make GTH TX work on RXOUTCLK (recovered from CDR) . If there are ppm differences between TX and RX reference clocks, then you need to use TX buffer in order to take care of this difference.
Ashish
Hello Ashish,
Thanks for reply.
Could you describe scheme (or provide a reference) for implement it (TX work at RX CDR clock)?
BR, Serge
Does use OBUFDS_GTE3(4) - is only one correct way to feed external clock synthesizer/cleaner by MGT RX CDR clock?
What about route out MGT RX CDR via FPGA fabric and general IO?
Moreover, is possible to use MGT RX CDR clock as reference for MGT TX without external synthesizer/jitter_cleaner if CDR clock route out via  OBUFDS_GTE3(4) for OTU2 application?
BR, Serge
Visitor kgadeyne
If you really have to go without an external jitter cleaner, have you considered using Xilinx PIcXO?
 You'll find a lot of info with that search term on the support site.
K.
