christine1225
Does ku115 xdma M_AXI_bypass support block read and write, not only register read and write?
Does ku115 xdma(3.0) M_AXI_bypass support block read and write, not only register read and write?
I  do the cmd,
./dma_to_device -d /dev/xdma0_bypass -f data/datafile0_4K.bin -s 1024 -a 0000 -c 1
sscanf() = 1, value = 0x00000400
sscanf() = 1, value = 0x00000000
sscanf() = 1, value = 0x00000001
device = /dev/xdma0_bypass, address = 0x00000000, size = 0x00000400, offset = 0x00000000, count = 1
error I got:
host memory buffer = 0x1cf0000
Segmentation fault
ubenevides
You have to use the memory mapped interface
# read
$ reg_rw /dev/xdma0_bypass 0x0000 w
# write
$ reg_rw /dev/xdma0_bypass 0x0000 w 1
