EN_VTC during modifying QTR delay
Hello
Whether BITSLICE_CONTROL.EN_VTC signal must be pulled Low during modifying PQTR/NQTR values?
Community Manager
Community Manager
Re: EN_VTC during modifying QTR delay
Doubled checked and you do not need to make the EN_VTC of the BSC low when changing the  PQTR/NQTR. It would be a good step after updating the PQTR/NQTR delay to read it back to make sure they got updated as programmed.
Sandy
Community Manager
Community Manager
When you are changing the delays of the BITSLICE you are meant to pull the EN_VTC of the BITSLICE Low, so it makes sense to pull the EN_VTC of the BSC low when you make a PQTR/NQTR change so that two things are not trying to update at the same time.
I'll try to verify that can get back to you.
Sandy
Community Manager
Community Manager
Sandy
