Error : writing data to FPGA manager firmware in Ultrascale+
I want to program my PL from PS in my Ultrazed board that has Zynq Ultrascale+.
I have enabled FPGA manager in kernel configuration  and made available FPGA manager driver in my kernel ( using petalinux 2016.3). When I initially tried writing .bin file of bitstream to firmware, it said " write error: invalid argument" . Can someone shed some light on this error?
I have referred to other forums and AR like https://www.xilinx.com/support/answers/68246.html and did those tweeks. Applied the workaround mentioned in pmufw and added it in BOOT.BIN. Still getting this error called "invalid argument"  error when I echo the binary format of bitfile to /sys/class/fpga_manager/fpga0/firmware.
$mount /dev/mmcblk0p1 /media
$ mkdir /lib/firmware $cp /media/bitstream.bin /lib/firmware/ $echo bitstream.bin > /sys/class/fpga_manager/fpga0/firmware
right after echoing bitstream.bin, I am getting
[ 1625.057033] fpga_manager fpga0: writing bitstream.bin to Xilinx ZynqMp FPGA Manager
[ 1625.079420] fpga_manager fpga0: Error while writing image data to FPGA
-sh: echo: write error: Invalid argument
Hi @pratham, Finally got the FPGA manager driver work with Petalinux 2016.3. I had to update the PMUFW.elf to version 0.2 (2016.4 sdk gives 0.2 version) and include that in BOOT.BIN to get it to work. Also I had to apply the patches to FSBL and U-Boot sources as mentioned in avnet github, to make the booting flawless in Ultrazed.
#Created using petalinux 2016.3
#Added SDHCI and PHY nodes to the device tree files manually , before building.
#Got SDHCI and PHY nodes format from Avnet Github.
#Also added patches to psu_init.c in the FSBL source and platform-top.h in U-Boot sources. Got patch files from Avnet Github.
#Also added memory node address  manually in the device tree. It was a bug in the petalinux 2016.3.
#used SDK 2016.4 to create version 0.2 of PMUFW.elf and included that in the BOOT.BIN
Please do not post duplicate.
https://forums.xilinx.com/t5/UltraScale-Architecture/FPGA-Manager-driver-with-petalinux-2016-3-error-in-writing-data/m-p/780703#M4771
-Pratham
Hi @pratham , Sorry for the duplicating the post. I had two accounts in here and accidentally used the other one. I would prefer to use this account to continue the discussion. I will delete the other one soon,
 I have followed the http://www.wiki.xilinx.com/FPGA+Manager+ZCU102 . I am able to do the PL programming in standalone mode ( wrapping fsbl, elf file generated by xil_fpga example, and design_1_wrapper.bit.bin ) to BOOT.bin. It was able to program PL with SD card boot.
But with the same .bit.bin file, I am not able to write to firmware from linux as I am still getting invalid argument error. Any other potential reasons coming to mind ?
Goutham
Also, I am afraid if this has to do anything with the petalinux 2016.3 version. I read in another post that firmware built with petalinux 2016.4 has many changes and wont need any patch. Can I build linux image using petalinux 2016.3 with sources of kernel taken remotely from xilinx-2016.4 commit of xilinx git? Can that cause conflicts? I am trying to avoid fresh installation of petalinux 2016.4
@gouthamp I think it is worth doing a clean build of 2016.4 and give it a try.
-Pratham
Hi @pratham
I have tried the same with petalinux 2016.4 and result is same. Also came across a well written blog https://www.invincealabs.com/blog/2017/03/ubuntu-ultrazed/ that uses petalinux 2017.1 , and still result is same. Only variable that I see here is FPGA board. I am using Avnet Ultrazed and not Xilinx boards. But I assume FPGA driver has nothing to do with the board. I have also came across a patch suggested by @debrajr in https://forums.xilinx.com/t5/Embedded-Linux/ZynqMP-PL-Programming-Throught-Linux-petalinux-2016-3/td-p/754914 . Planning to apply the patch and try again.
Please let me know if any other thoughts are coming to you.
Goutham
could you tell me how to update PMUFW.elf ? thanks
