kostas_p
GTH 16.3 Gb/s Transceivers length on PCB
I would like to ask what is the maximum length of a PCB trace that can be routed for a GTH 16.3 Gb/s Transceiver. I have read that the Xilinx FPGAs provide unique auto-adaptive receiver equalization built directly in hard logic.
Is it safer to use a retimer or to use the auto-adaptive receiver equalization which the FPGA supports?
Thank you!
austin
k_p,
When you simulate your intended channel, you will see if it works.
As simple as that:  use the simulation models.  Without signal integrity analysis of your layout, with your board's actual construction no one can answer honestly.  The videos clearly demonstrate our superiority and use a standard reference backplane, but your system might not be exactly the same.
http://www.xilinx.com/video/fpga/virtex-7-x690t-gth-demo.html
Austin Lesea
Principal Engineer
Xilinx San Jose
