Newbie hofith
High Speed SelectIO IP - TX serial data different from TX IP input
We're trying to use the High Speed SelectIO IP's example design to send serial data in a rate lower than 100Mbps
For this we use the TX with the 8bit input in 125MHz, for 1000Mbps data rate and send every bit 16 times.
The problem is, the serial interface only sends 0 or F.
For instance, if B is inserted, meaning 1*16,0*16,1*16,0*16,
On the serial line we see 1 for 64ns - meaning 4 bits of 1, indicating F
We'd appreciate your help with solving the issue.
Hofit
Community Manager
Community Manager
Re: High Speed SelectIO IP - TX serial data different from TX IP input
Hi @hofith
I'm struggling a little to understand the setup.
My understanding is that the core_data_from_fabric_xx input of your HSSIO is "00" "00" "FF" "FF" repeating, giving a serial stream of 16 0's, then 16 1's.
In the screenshot the signal names are missing, I'm assuming the first signal is the serial clock, is the second the data to the TX_BITSLICE? Its wider than 8 bits and doesn't match the description of  0000FFFF.
I did a quick simulation with the example design and just changed the test data to 00 FF and the simulation output is as expected.
If you could explain further the screen shot I can try to make my simulation match yours.
Sandy
