How to control the TX_BITSLICE and RX_BITSLICE of Kintex Ultrascale?
I am trying to use the RX_BITSLICE and TX_BITSLCE as high speed LVDS interface, But I don't want to use the BITSLICE_CONTROL block,because it will limit the location of IO .
My problem is how to control the RX_BIT_CTRL_IN<39:0> and TX_BIT_CTRL_IN<39:0> ports of  RX_BITSLICE and TX_BITSLCE? What does every bit mean?
Thank you in advance for your help .
Hello @4280336
You have to use BITSLICE_CONTROL block for using RX_BITSLICE and TX_BITSLICE components.
TX_BITSLICE/RX_BITSLICE contains output/input delays that can be continuously corrected for VT variation by BITSLICE_CONTROL and serialization logic for either 2:1, 4:1, or 8:1.
Vinay
