How to implement 10 bit SERDES in Virtex UltraScale?
Hi guys,
I need to build 10-bit SERDES from OSERDESE3 but this primitive is not support cascading any more. One solution is to use 10:8 gearbox before OSERDESE3. Is there another way to work around this?
Re: How to implement 10 bit SERDES in Virtex UltraScale?
10:1 is not natively supported, a gearbox is the solution. We have anew XAPP for 7:1 which can be found here. This could be used as a starting point for a 10:1 design: https://www.xilinx.com/support/documentation/application_notes/xapp1315-lvds-source-synch-serdes-clock-multiplication.pdf
Thanks. I'm working on gearbox now. I just wonder why you guys remove cascading feature from OSERDESE3. It can save lots of work.
Community Manager
Community Manager
The Component mode in UltraScale has a reduced feature set than in previous families, no build-in Bitslip, no Cascade, no SDR mode, only supports data widths of 4 and 8.
What was improved was the Built in Self Calibration BISC to give better tracking across VT. The real improvements are around performance, in memory / native mode the SelectIO support 2.4Gbps DDR4.
Sandy
