ISERDESE3 - Configuring it in DDR mode
Wondering how to configure ISERDESE3 in DDR mode.
I don't see the parameter "DATA_RATE" found in ISERDESE2, which can be used to set the data rate to DDR or SDR.  Below is the ISERDESE3 instantiation template found in the library guide.
ISERDESE3 #(
.DATA_WIDTH(8), // Parallel data width (4,8)
.FIFO_ENABLE("FALSE"), // Enables the use of the FIFO
.FIFO_SYNC_MODE("FALSE"), // Enables the use of internal 2-stage synchronizers on the FIFO
.IS_CLK_B_INVERTED(1'b0), // Optional inversion for CLK_B
.IS_CLK_INVERTED(1'b0), // Optional inversion for CLK
.IS_RST_INVERTED(1'b0), // Optional inversion for RST
.SIM_DEVICE("ULTRASCALE") // Set the device version (ULTRASCALE, ULTRASCALE_PLUS, ULTRASCALE_PLUS_ES1,
// ULTRASCALE_PLUS_ES2)
) ISERDESE3_inst (
.FIFO_EMPTY(FIFO_EMPTY), // 1-bit output: FIFO empty flag
.INTERNAL_DIVCLK(INTERNAL_DIVCLK), // 1-bit output: Internally divided down clock used when FIFO is
// disabled (do not connect)
.Q(Q), // 8-bit registered output
.CLK(CLK), // 1-bit input: High-speed clock
.CLKDIV(CLKDIV), // 1-bit input: Divided Clock
.CLK_B(CLK_B), // 1-bit input: Inversion of High-speed clock CLK
.D(D), // 1-bit input: Serial Data Input
.FIFO_RD_CLK(FIFO_RD_CLK), // 1-bit input: FIFO read clock
.FIFO_RD_EN(FIFO_RD_EN), // 1-bit input: Enables reading the FIFO when asserted
.RST(RST) // 1-bit input: Asynchronous Reset
Re: ISERDESE3 - Configuring it in DDR mode
Hi @xilinxmax
You must be knowing whether the incoming data is SDR or DDR.
If the Data is DDR  and required de-serialization ratio is 1:8,  CLK_DIV = CLK/4.
If the Data is DDR  and required de-serialization ratio is 1:4,  CLK_DIV = CLK/2.
In short if you know the data nature and set the DATA_WIDTH attribute and Derive the CLK_DIV properly, you will get the expected de-serialization  i.e there is no need to have DATA_RATE attribute explicitly.
Follow this table for desire de-serialization
Reply if you have any queries , Give Kudos and accept as Solution
Hi @xilinxmax
