taganrog
Independent control of QTR delays
Hello
Can I increment NQTR delay independently, without incrementing PQTR delay?
sandrao
Community Manager
Community Manager
I doubled checked and they can be independently controlled. They’re two different registers with different controls, the delays are 512 taps so you could move them apart by as much as the delay line allows.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
sandrao
Community Manager
Community Manager
Physically they are two separate lines with separate RIU registers so I think its possible though I’m not sure I understand the use case. Why do you want to move the P & N QTR delays away from each other?
Sandy
taganrog
Data valid windows can be different. And clock edges can has different positions in the windows. So one QTR delay can stop during calibration, when the other QTR delay can continue to move.
PG150: "The data captured in the PQTR clock domain is transferred to the NQTR clock domain before being sent to the read FIFO and to the general interconnect clock domain. Due to this transfer of clock domains, the PQTR and NQTR clocks must be roughly 180° out of phase. This relationship between the PQTR/NQTR clock paths is set up as part of the BISC start-up routine, and thus calibration needs to maintain this relationship as part of the training (BISC_ALIGN_PQTR, BISC_ALIGN_NQTR, BISC_PQTR, BISC_NQTR)."
Thus, how far I can move apart P & N QTR delays from each other?
sandrao
Community Manager
Community Manager
Sandy
taganrog
Do I need to maintain any relationship between the PQTR/NQTR clock paths as pointed in PG150?
