yurivn
Internal "clock" divider latency
Hi everyone,
When I create 2 signals with 10ms period from clock 62.5MHz and 122.88MHz, I saw that the distance between 2 signals is not constant after running a long time. Anyone can explain this issue? I thought that it will remain the distance between 2 signals because it has the same period (10ms)?
Ps: With clock 62.5MHz, I have 625000/2 cycles for high level '1' and 625000/2 cycles for low level '0'
      With clock 122.88MHz, I have 1228800/2 cycles for high level '1' and 1228800/2 cycles for low level '0'
Thank you,
Yurivn
andrewlan
How are your 2 clocks generated? If they are from 2 crystals, then you are seeing the ppm differences between them. If using an MMCM then you will probably see the actual frequency is not the same as the requested.
pthakare
Hi @yurivn
Can you elaborate more on distance between two signals ?  May be you can attach the Simulation or ILA screenshot explaning the same.
If i presume correctly you mean the phase difference between two signals is not constant throughout , Is it the case?
Did your observations based on Simulation or Hardware results ?
Reply if you have any queries, give kudos and accept as solution
drjohnsmith
Did you mean the two frequencies to be integer divisions of each other ?
 Thinking of the findamental sine wave you have, 122.88, and 62.5 , they are not integer divisions of each other,
If they were 122.88 and 61.44, as used in telecom , then they would stay in sync,
Two different frequencies not integer division related are goign to beet, as you have seen.
andrewlan
yurivn
@andrewlan @drjohnsmith @pthakare
A problem is 2 clocks are generated from 2 different clock source, so it makes a different between 2 clocks after a long time running.
