josh_tyler
Internally terminating LVDS_25 inputs on a HR bank
I posted this earlier this morning, but for some reason it was flagged as spam and removed...
I have a Zynq Ultrascale+ design, and I want to have LVDS inputs into a HR bank using internal termination. UG571 (v1.11) p.126 says that this is supported if the Vcco is 2.5V (which it is), and the LVDS_25 I/O standard is used.
I have tried to do this, but the IO planning window in Vivado doesn't allow DIFF_TERM_ADV to be set for these inputs. Setting it manually in the xdc file causes the following error during placement.
[DRC PORTPROP-6] I/O standard compatibility with attribute usage: Port clk_p has property DIFF_TERM_ADV set, but its I/O Standard, LVDS_25 does not support this property.
What am I doing wrong?
Here is a minimal example. Create a new project in Vivado 2019.1 targeted towards xczu7ev-fbvb900-1-e, and add the following files. Attempting to implement the design will result in the above errror.
Top.vhd:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
entity top is
    Port ( clk_p : in STD_LOGIC;
           clk_n : in STD_LOGIC;
           test : out STD_LOGIC);
end top;
architecture Behavioral of top is
    signal clk : std_logic;
    signal test_buf : std_logic;
begin
    buf : IBUFGDS
    port map (
        O => clk,
        I => clk_p,
        IB => clk_n
    test_buf <= not test_buf when rising_edge(clk);
    test <= test_buf;
end Behavioral
constraints.xdc
set_property IOSTANDARD LVCMOS33 [get_ports test]
set_property PACKAGE_PIN L15 [get_ports test]
set_property IOSTANDARD LVDS_25 [get_ports clk_p]
set_property IOSTANDARD LVDS_25 [get_ports clk_n]
set_property PACKAGE_PIN G13 [get_ports clk_p]
set_property DIFF_TERM_ADV TERM_100 [get_ports clk_p]
set_property DIFF_TERM_ADV TERM_100 [get_ports clk_n]
gnarahar
@josh_tyler  You are using Zynq Ultrascale + device which has only HP and HD banks. No HR banks.
HD Banks don't support DIIF_TERM. Below snippet from Page#343 of UG571 v1.11.
Hence you getting the DRC
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
drjohnsmith
A quick guess,
I think you only have to define the _P side of a diff LVDS,
   How have you created these constraints, by text or in the tools ?
josh_tyler
Yes I agree that you should only need it on one, but the tools added IOSTANDARD LVDS_25 to both, so I tried to be consistent with that.
IOSTANDARD and PACKAGE_PIN constrains were generated using Vivado I/O planning. DIFF_TERM_ADV was added manually because the I/O planning tool wouldn't let me set it.
It would implement okay without DIFF_TERM_ADV set, but I want the internal termination to be used.
@josh_tyler
IBUFGDS is not actually a valid primitive according to UG974.  Instead, try using IBUFDS, as described in UG974.
Mark
josh_tyler
markg@prosensing.com
Thank you for the suggestion! I've just tried it, and it gives the same error.
Josh
drjohnsmith
I think thats a clue,
if the tools would not let you add the termination, its not valid.
drjohnsmith
Taking step back,
can you instantiate a different receiver, from unisim that has the option for temination on / off ?
I seem to rember there was one , but sorry I dont have vivado here to try.
josh_tyler
I agree with you, except for the fact that Xilinx' documentation tells me it is a valid configuration (UG571 (v1.11) p.126). I think I must be configuring something incorrectly in Vivado, but I would like to know how to configure it correctly.
josh_tyler
@drjohnsmith wrote:
Taking step back,
Good idea, I've just tried this (using IBUFDS_DIFF_OUT_INTERMDISABLE, which seems to be what you were referring to), but unfortunately it gives the same error.
gnarahar
- Giri
josh_tyler
Thanks @gnarahar, I knew I must be doing something silly!
