saban
KCU105(Kintex Ultrascale) is not listed in Vivado 2014.4.1 as eval board
I installed Vivado 2014.4 and 2014.4.1 subsequently and Vivado does not list KCU105 as eval boards on creating project.
I uninstall and install again but result is same.
2014.4.1 says: This update is Ultrascale related but I could not see KCU105 and also "Ultrascale FPGA Gen3 Integrated Block For PCI Express" is not listed in IP Catalog.
My system is Ubuntu 14.04 LTS and I have using Vivado 2014.4.1 for 1 year without any problem with KC705 eval board.
I want to use KCU105 after that, but Vivado interrupts my way.
I attached related screen shots also.
Thanks a lot.
Screenshot from 2016-04-13 17:56:00.png
pratham
@saban this is expected, board has been added from 2015.2. please download 2015.2 or later version
-Pratham
pratham
-Pratham
saban
Hi Pratham,
Thanks a lot.
vijayak
Hi @saban
Just for your reference with 2015.2 where you can see KCU105 board listed.
Thanks,Vijay
