kastor_yj
LVDS input driven by standby driver
I have a design use LVDS input clock which is driven by an ADC. I want to put the ADC into standy mode to save power, but found ADC power off its LVDS driver in standby mode. Then the FPGA's LVDS input buffer get differential signal with input level less than the Vidiff spec, and cause noisy clock during ADC standby period.
How to get a clean LVDS input when the driver is powered off?
Thanks a lot,
Jun
drjohnsmith
LVDS iputs 'oscilating' is a common problem when not being driven,
    this is a good start point
https://www.onsemi.com/pub/Collateral/AN-5046.pdf.pdf
TI , also have an app note, AN-1194 I have a print out of,  but the Ti site is down at the moment,
I assume "power off the ADC driver" means high impedance.
In that case, some weak pull up/ pull down may sort that out.
kastor_yj
I have tried week pull-up on N node and pull-down on P node. It doesn't help because there is a 100 Ohm termination between P and N. The pull is too weak to generate enough voltage across that 100 Ohm.
@kastor_yj
Sure, you have almost zero between p and n and any noise picked up makes trouble.
What about just one pull-up or pull-down? so you have both lines high or low because of the termination. I think (not sure, though) in that case the receiver won't toggle.
alternatively, have a look at this document, Fig 1-72:
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
I just realized the above is rubbish, is what you did and doesn't work for you...
Then the thing is, if you bias your line and still get false clocks, you are picking up noise, that's the problem.
So the solution would be a neat routing protected from aggressors. Maybe late if you already have a board made...
Couldn't you tie up the ADC enable to a clock enable so you stop any noise clock when the ADC is off?
drjohnsmith
Oh, dear... they need a wall to fix that
kastor_yj
Thanks a lot. This looks good, will modify the PCB to get it implmented. It's a pity the FPGA internal pull-up and pull-down resistor is too weak and can't eliminate the differential noise completely.
