MTS Design (8x8) Non Existence of MTS radio button in RFDC Evaluation GUI
While following the steps for the MTS design flow in the design guide, I do not see the MTS button in the DAC and ADC subsystem as seen in the figure. My version of the RF Data Converter Evaluation User Interface (TRDv1.4) does not seem to have these radio buttons and I am not able to proceed after Step 5 in the below tutorial for MTS Design (8x8). I took this below figure from step 11 of the following document -
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57803102/MTS+Design+8x8
Community Manager
Community Manager
Hi Arve9066,
It might need you to add the following in your RF_DC_Evaluation_UI.ini file to enable MTS.
[Display]
ShowMTS = TRUE
EnableAdvancedClocking = True
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
