Hello everyone,
I am facing some issues with performing the multi-tile synchronization on my ZCU 1275 RF SoC. Coming to the details, I am building a project where I need 8 DACs, which corresponds to 2 data converter tiles on the RF SoC architecture (each tile contains 4 DACs and a driving clock). The driving clock for each tile is 2.048 GHz generated from the external hardware clock module that contains 3 PLL sources. The clock inputs of the two tiles under consideration are connected to 2 PLL sources. However, I found out that for the DAC outputs for both tiles to be in-phase, we need to perform multi-tile synchronization. I am following the PG269 document for this. The multi-tile synchronization (MTS) feature enables multiple converter channels working with an aligned and deterministic latency across tiles and chips. I could enable this feature for the "Data-converter" IP that I am using in my design. Enabling this further adds a pin "user_sysref_dac," which is a PL SYS Reference input. The "PG269 RF SoC Data converter user guide" gives a set of guidelines to perform the MTS from pages 169-177. And primarily, the SYSREF frequency must meet the following requirements as given :
- If synchronizing RF-ADC and RF-DAC tiles with different sample frequencies, the frequency must be an integer submultiple of GCD(DAC_Sample_Rate/16, ADC_Sample_Rate/16)
- SYSREF must also be an integer submultiple of all PL clocks that sample it. This is to ensure the periodic SYSREF is always sampled synchronously.
- Less than 10 MHz
I get 8 MHz as SYSREF frequency for my design with 2048 MHz as my DAC_sample_Rate following the above instructions. I generated this 8 MHz reference signal using the "CLOCKING_WIZARD IP" from the 300 MHz LVDS oscillator. This is passed through a register driven by the PL clock before being connected to the "user_sysref_dac" pin of the data converter IP as described in the document. But after enabling this MTS feature and performing the above extra steps, the timing fails; I should be doing something wrong, so I will appreciate it if I can get some help with this.
I have attached the PG269 document, my Vivado project, and the schematic, and the error message that I receive.
Please let me know if you have any further questions. Thank you very much!
Sravan
