Need for reset the PLL during native mode reset sequence
Hello
UG571: To apply a reset:
1. Assert reset to the PLL.
2...
Is it obligatory? What for? Can I stop the CLKOUTPHY high-speed clock only instead of reset the entire PLL?
Is it obligatory to reset and MMCM too, if I generate APP_CLK and RIU_CLK from MMCM, not from PLL?
Scholar jmcclusk
Re: Need for reset the PLL during native mode reset sequence
From UG571:
When an application is running in an FPGA, apply the following steps to safely reset the application and allow a correct bring-up afterward:
Apply Reset
To apply a reset:
2. Apply reset to RXTX_BITSLICE.TX_RST_DLY, RXTX_BITSLICE.RX_RST_DLY, TX_BITSLICE_TRI.RST_DLY, RXTX_BITSLICE.TX_RST, RXTX_BITSLICE.RX_RST, TX_BITSLICE_TRI.RST, and/or BITSLICE_CONTROL.RST.
3. Stop strobe clocks.
4. Wait the minimum PLL reset assertion time before releasing the reset. For this timing specification, consult the PLL section of the UltraScale device data sheets [Ref 2]. Then follow the steps in Native Mode Bring-up and Reset, page 299 for correct bring-up
