kikd180
Noise like spur at ZCU111 ADC
Hello.
I'm using ADC at following setting.
  •  Fs = 3932.16MHz(Internal PLL is bypassed)
  • Decimation=8x
  • Mixer Freq. = 491.52MHz
Check ADC spectrum not receiving signal via RF Analyzer, ADC appears to receives noise(up to about -90dBm) at 0 MHz as picture.
I have 2 questions about this.
  1.  Who knows the cause of this noise?
  2.  Is there a workaround?
Best regards.
Tags (2)
pthakare
Hi @kikd180
It seems you are only capturing noise , Try to give the valid single tone/dual tone or Modulated signal and observed the spectrum.
With the noise only , ADC Callibration is not converging and Spurs are expected.  Please refer to ADC calibration mechanism section  in our IP  product guide for more
detailing.  page 53
https://www.xilinx.com/support/documentation/ip_documentation/usp_rf_data_converter/v2_2/pg269-rf-data-converter.pdf
pthakare
Hi @kikd180
detailing.  page 53
kikd180
Hello @pthakare
Thank you for reply.
I tried give modulated signal.
And after a few seconds, I changed calibration state to "Freeze".
Noise was reduced than ADC receive no signal.
Best regards.
