m006
Voyager
Voyager
PCIe Gen1-->Gen3 negotiation for ultrascale GTHE3
The PLL switch is implemented by DRP configuration for 7 series GTHE2
but ,it seems that the  ultrascale GTHE3 doesn't use DRP control FSM.
how to implement the PLL ration dynamic change?
venkata
in 7-series GTH, CPLL does not support Gen3 speed so QPLL needed to be used. In UltraScale, CPLL can support Gen3 speed also. So PLL switch is not necessary.
