PLL IP in Xilinx Vivado
I am using Zedboard for this experiment.
I am trying to use PLL IP to generate 100MHz clock by providing clk_in1 as 20MHz. Then use this 100MHz in another module. So, I am confused about how to use it. I have few questions,
1. In clocking wizard, I select PLL and then provide the value of clk_in1 as 20 and clk_out1 as 100. So, do I need to do Generate output products as Out-of-context module or Global ?
2. And how to write the constraint file if I want to generate the bitstream it will need pin location for all I/O ports then clk_in1 has to be connected to which pin location? We cannot connect it to Y9 (clk pin of Zedboard) because it is 100MHz.
Currently, I have written a create_clock constraint to generate 20MHz but to generate bitstream we have to provide the location of clk_in1 so what should I provide?
Shivani Shah
pthakare
Hi shivani.shah@iiitb.org
You need a 20MHz reference clock input ,
So wanted to check what is the source of 20MHz reference clock input (clk_in1)?
Hello @pthakare,
Thanks for your response.
Yes, how to provide the source for 20MHz reference clock input (clk_in1) and while writing pin location what should I write, because Bitstream will not generate if I don't provide a pin location to any I/O port.
I also found this link, but not sure how to use it.
https://www.xilinx.com/support/answers/62488.html
pthakare
You should have clock source providing 20Mhz on the board and output routing to clock capable pin of FPGA.
If so , you need check on what FPGA pin the clock is coming and write the location constraint/IOSTANDARD constraints based on it
Hi @pthakare,
Ok, I will check for the pin on board providing me 20MHz and then try to work around that.
