sultanabdul1997
PS MIO Vol(max) characteristics
Hi Team,
We are currently using XCZU27DR-2FFVE1156I with PS MIO configured as LVCMOS18 in our design, the stated Vol(max) is 0.45V for Iol of 12mA as per DS926 document. Our application requires lower Vol levels and draws lower current, Is there a characterization graph of Vol vs Iol? or could you provide Vol levels for different Iol levels?
Sultan.
sandrao
Community Manager
Community Manager
Hi @sultanabdul1997
You might find the IBIS models of use : https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/device-models/ibis-models/zynq-ultrascale-plus-mpsoc.html
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
sandrao
Community Manager
Community Manager
Hi @sultanabdul1997
Sandy
sultanabdul1997
Thank you very much, we will use the model for simulation and get back to you if any more clarification is needed
