joe306
PS Reference Clock Frequency Selection
Hello, I am designing a board with an Zynq Ultrascale+ MPSOC XCZU7CG-1FFVC1517I. I am deciding the frequency of the PS Reference Clock and see that on many of the Development boards they use 33.33Mhz. I would like to use 60Mhz. Is there a reason why so many Dev Boards choose 33.33Mhz?
I'm choosing 60Mhz so I'm able to get better clock resolution when I have the PS generate clocks for the PL side.
Thank you,
Joe
joe306
sandrao
Community Manager
Community Manager
Hi @joe306
The Data Sheet has a section on the PS REFCLK requirements : https://www.xilinx.com/support/documentation/data_sheets/ds925-zynq-ultrascale-plus.pdf
You just need to ensure your choice meets the requirements.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
joe306
