leeting
Physical and system MPN not match for , MPN#XCKU115-2FLVA1517E
Please advise why physical body marking MPN is different with the system MPN? Thanks
Physical body marking MPN#XCKU115-FLVA1517AAY
System MPN#XCKU115-2FLVA1517E
gnarahar
@leeting I don't see a discrepancy. Your System MPN#XCKU115-2FLVA1517E which means it is a Commercial Grade Kintex Ultrascale Ku115 device in FLVA1517 package, -2 speed grade and "Extended (E)" temperature grade.
On your Device Marking, you should have a 2D barcode. You need to scan it, to retrieve the Speed and Temperature grade of the device. Please refer to this document: https://www.xilinx.com/support/documentation/customer_notices/xtp424.pdf which has information for you to retrieve the information.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
