02-06-2019 05:38 PM
I am using the xtp427 ultrascale-plus schematic review checklist to review my Zynq US+MPSoC schematic. The checklist says to place 2.0kohm pull-up resistors on the SPI MISO and MOSI signals near the SPI device (with no other explanation). I cannot find any other Xilinx documents that recommend a pull-up on MISO, MOSI. For example, UG583 pg 178 recommends pull-ups on SPI SS pins, but no mention of pullups on MISO, MOSI. We are interfacing to a Cypress QSPI Flash (S25FL256) which also has no recommendation for pull-ups on MISO, MOSI. Are these pull-ups really required? And if so why?
Thanks, Ted
02-06-2019 07:58 PM
Oddities like this recommendation are generally the response to unexpected operation in the absence of the recommended action. Since the SPI interface can be operated as a master or a slave, it is likely that the circuitry can get confused if the MOSI and/or MISO lines are not pulled high at some point during system operation.
If you wait long enough, you might get a more-official response like this:
https://forums.xilinx.com/t5/7-Series-FPGAs/PS-MIO-SPI-pull-ups/m-p/902053
-Joe G.
02-06-2019 07:58 PM
-Joe G.
02-07-2019 05:59 AM
Thank you very much Joe. I will include the resistors in my design.
-Ted
