natanf
RF Analyzer with the ZCU1275
i am using the RF analyzer with the ZCU1275 and when i try to acquire data it shows me this error. what could be the problem and is there a full and understandable tutorial for the RF analyzer with the ZCU1275.
my second question is what are the differences between the RFDC eval gui and the RF analyzer? when and for what purpose should i use each one of them?
and in particular which one should i use to evaluate the ZCU1275?
thank you very much in advance
pthakare
Hi @natanf
Here are the blogs on RFSoc which have detailed information
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Analyze-This-Unboxing-the-RF-Analyzer-Tool-Part-One/ba-p/964731
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Analyze-That-Unboxing-the-RF-Analyzer-Tool-Part-2/ba-p/987241
in addition to this chapter 5 in UG1309 dedicated for RF Analyser
https://www.xilinx.com/support/documentation/user_guides/ug1309-rf-data-converter-interface.pdf
The answer to your second question is evaluation GUI runs on targeted reference design (TRDs) whereas RF analyser can be used to debug the data converter IP in your custom design.
pthakare
Hi @natanf
