gd8021
RF analyzer
I'm trying to valuate the MTS on a customer ZU48DR board with RF analyzer.
However it seems could not enable the MTS from the RF analyzer GUI, see below.
Any suggestions? ASAP.
pthakare
Hi @gd8021
Is the MTS option enabled while configuring the IP?
gd8021
Hi Pthakare,
I running the files from the RF Analyzer installation directory.
pthakare
Hi @gd8021
Is the board you are using is custom board with  ZU48DR device or ZCU208 evaluation board ?
Are the clocks programmed properly before opening the RF analyzer ? I mean MTS required PL sysref and analog sysref , is the LMK programmed accordingly to provide the required frequency PL SYSREF and ANALOG SYSREF
gd8021
#1
It's a customer board. The clock, SYSREF for both PL and DAC are set.
#2
CLK_DAC0 is used for all AXI4 streaming interfaces.
