Observer chintan_asi
RFSOC ADC PLL
HI,
On the RFSOC devices, can the ADC sampling clock be separate on each tile? I know there is a separate clock input per tile, but can sample clock actually be different?
CHintan
Re: RFSOC ADC PLL
In a 25/27/28DR device there are 4 ADC tiles
Each tile as 2 4GSPS ADC channels
The clock input to the tile can be the direct sample clock for both ADC channels
Or
The clock input can feed a PLL which provides the sample clock to both ADC Channels.
So each Tile can run at different sample rates, but FS for the ADC channels will be the same.
Similarly:
In a 29DR device there are 4 ADC tiles
Each tile as 4 2GSPS ADC channels
The clock input to the tile can be the direct sample clock for all four ADC channels
Or
The clock input can feed a PLL which provides the sample clock to all four ADC Channels.
Re: RFSOC ADC PLL
Or
Similarly:
Or
