spann
RFSOC LMK04208 clock source
Hi all:
We want to change  LMK04208 input clok source from Clkin0 to Clkin1
Can you help me how to configure it ?
klumsde
Hi @spann
If you pull out the jumper J110 this will power off the TCXO
I think you may have to program the LMK to take the PLL input from the CLKIN1 input
You can download the ticsPro SW and load the profile you would normally use then select the input from the other source. ticspro_lmk_sma.JPG
You should check with the TI docs here though to be sure this is needed.
pthakare
Hi @spann
This is purely LMK04208 on board  PLL issue and your best bet is to check this with Texas Support.
As far as i know  " Which reffernece to use is deviced by  external pins Status_CLKin0 and Status_CLKin1 input of LMK04208"
LMK04208 datasheet have detailed description around this.
drjohnsmith
Try this
http://www.ti.com/lit/ds/symlink/lmk04208.pdf
look at section 8.1.2
you dont say what your board is,
   but most / all xilinx eval boards have great docs that explain this sort of thing,
e.g.
https://www.xilinx.com/support/documentation/boards_and_kits/zcu111/ug1271-zcu111-eval-bd.pdf
klumsde
Hi @spann
klumsde
Reading the doc from @drjohnsmith
There is some suggestion that if one input is gone it can automatically switch to the other one.
So powering off the TCXO may be enough here.
Cheers,
Keith
