RFSOC noise samples
We need to decide whether to use Gen1 or Gen3 RFSOCs for a product.
Our main selection criterion is the broadband ADC noise. We would like to have a close look at it than just doing some math on the NSD number in the data sheet.
Is it possible to get a larger sample (128k samples or more) of ADC noise data for these chips? Maybe someone with an evaluation board could connect the input to GND and creat sample data for us?
That would be very helpful.
Kolja Sulimma
kolja@cronologic.de
drjohnsmith
That would be a random sample of one your after then ?
That will give yo no more info than the data sheet,
If you want to investigate the noise, you need to get a board yourself and do the tests you want, at the clock rate you want,
Does this mean that the NSD is entirely flat over the full frequency range?
I would suppose that there is at least some frequency dependancy in the noise that is not represented by the NSD figure.
Also, there are no Gen3 boards availabe that I am aware of so I was hoping that someone inside Xilinx could provide that data.
4096 Msps for both chips and 5Gsps for Gen3 would be the ideal dataset for us, but we could probably learn a lot from different sampling rates as well.
Kolja
drjohnsmith
I agree with your concerns,
and as you say the response is going to be none flat,
But
what you see is going to see is HIGHLY dependent upon the test enviroment,
Which is why companies publish data sheets of what they garuntee and typical in specific circumstances,
Personally, I dont think any company could run all the test that could be deemed desirable, so no company does.
You need to get eval boards of what you can, simulate what you can, extrapolate where you can, and build your own test set up for any specifics,
zhendon
Community Manager
Community Manager
Hello
Here is my two cents,
If you are looking for the detail NSD testing result in full bandwidth. you can please reqeust to access this website and download the char report of Gen1 device.
https://www.xilinx.com/member/zuplus_rfsoc_char_reports.html#overview
thanks,
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Thank you.
However, if I understand the NSD plot in that document correctly, it shows the full bandwidth NSD plotted against the frequency of a -1dB sine wave fed into the ADC.
What I am looking for is the spectrum of the noise with no input (or a fixed frequency input). Or the same data in the time domain.
Kolja
klumsde
Not providing the ADC with an input is going to have implications for the background calibration. This needs energy to converge. What is the real purpose of this test? It is not clear to me.
We need to detect pulses on the input. Our key performance characteristic is the ration between full scale and the smallest pulse that we can detect.
If the noise is perfectly white this ratio is given by the SNR measured either with a low frequency input or low amplitude input or computed using the noise histogramm (we don't care about distortion for this metric).
The characterisation report therefore contained the information that low frequency inputs improve the noise by about 1dB, which is good to know.
However, for non-white noise we can do better or worse than the SNR, depending on the shape of the noise. I need information on the noise shape as a spectrum or a set of noise samples to compute the dynamic range that we can achieve.
e2v and ADI simply sent us sample data when we asked for that. TI needed us to jump through some bureaucracy loops and our Xilinx FAE did nothing for a couple of months but now wants to lend us a Gen1 evaluation board for measurements.
Kolja
drjohnsmith
strongly suggest you get the board offered then, you will have the ability to test what you want to then, without the pre conceptions the others have put on their random sample of one measurements.
klumsde
Hi kolja@cronologic.de
I think it makes sense to try it out for yourself. I find the approach is a little unorthodox. I guess the idea of taking the noise profile and trying to extrapolate the SNR is not what I am used to.
It is a combination of the ADC quantization, thermal noise(the Capacitive elements of the ADC for example) then the clock jitter.
As you have seen backing off the input or looking at lower frequency CW improve SNR. This is directly because you are less impacted by the clock uncertainty at the sampling instant.
that is exactly why I need noise data to do calculations myself:
The equations you are quoting are valid only for sine waves. For our problem the effects of quantisation noise and jitter are zero. We are only concerned with noise sources that exist for DC inputs.
Beside thermal noise and flicker noise there might noise from other parts of the system coupled by power supply or EMI.
There are provable optimal filters for detecting small pulses in noise. If the noise is white I can derive the dynmic range in closed form. If not I need a histogramm of the filtered noise to compute it.
