viduneth
RFSoC ADC output
Hello:
I am trying to test the ADCs of the HiTech HTG-ZRF8-R2 board (featuring the ZU28DR chip). I am using the Vivado 2019.2 tool setup and I am seeing ADC output format to be different from what the datasheet states.
Data Converter IP settings (Xilinx Data Converter [XDCIP]  IP 2.2 ) are:
Sampling rate: 4.096 GSps
Decimation mode: 8x
Samples per AXI4-Stream clock edge: 2 (corresponds to a clock =256 MHz)
Mixer mode: real -> real
Nyquist zone: 1
Calibration mode: 2
According to the XDCIP the stream words (2 words per clock in my case with 32 bits) consists of 2-bytes which contains of ADC data 12-bits left-shifted by 4. But when I use an ILA to capture the samples (both [31:16]  and [15:0] separately), I see that all 16 bits change. In other words, I am expecting to see the 4 most LSBs to be zeros but I am seeing them carrying some data. Could anyone please let me know if I am missing something here or if this is the expected behavior?
Thank you,
Viduneth
Tags (3)
patocarr
Hi @viduneth
  I think you're assuming the padded bits will be zero when that may not be the case. Just take the MSB as defined and ignore the padding LSBs.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
patocarr
Hi @viduneth
-Pat
pthakare
Hi @viduneth
This is expected ,
Bits [3:2] will toggle due to interleaving calibration and dithering
We can ignore this as ADC is 12 bit accurate.
viduneth
Thank you for confirming this @pthakare @patocarr...
chaooxford
Hi viduneth,
do you have any example design with ADCs running? like an vivado and sdk project or so?
Best regards,
Chao
viduneth
Hi Chao,
Sorry for the very late reply as I hadn't noticed your post.
Do you still need this?
Viduneth
chaooxford
Hi Viduneth,
Thanks very much for your reply. I still need this. I have sent you an private message in xilinx account with my contact details.
Best
