gd8021
RFSoC DAC Gen3
It says that ZU48DR DAC maximum data rate is 10Gsps in the datasheet.
We have ZU48DR-FSVG1517-2-E.
However it shows 7Gsps in the converter IP configuration even real-to-real (DUC bypass).
How to set-up to run at 10Gsps.
ASAP - thanks.
pthakare
Hi @gd8021
What is the VIVADO version your are using ?
There are additional considerations for 10GSPS DAC sample rate and capture here
https://www.xilinx.com/support/answers/76313.html
Please refer to attachment in this AR
gd8021
Hi Pthakare,
I'm using version 2020.2
It's restricted on the IP configuration GUI when the datapath mode is DUC 0 to Fs/2 (Full Nyquist DUC mode). Which is no more than 7Gsps.
Was it true that I could not go any higher when using full band DUC? Thank you.
pthakare
Hi @gd8021
Greater than 7GSPS is supported for Mode2, 3 and 4.
Already replied to you on another similar thread.
