gd8021
RFSoC DAC
Questions about CLK_DACx (x = location of the DAC):
#1
according to the example design simulation to the DAC, for instance DAC0 more specifically here:
1) it sets the DAC tile register 0x4008 and 0x4004 bit[0] to '1'
2) write data samples and then set Reg 0x4008 to 0x00000108" and Reg 0x4004 bit[1] to '1' again
3) write Reg 0x200001100, 0x200001200 and 0x200001300 with zeros following by setting 0x4008 bit[3:0] to x"6" and 0x4004 bit[1] to '1' once again
the CLK_DAC0 is showing up after these.
#2 my questions:
Q1: according to the datasheet, the power-on sequence is done automatically once power applied without any user intervention, right? Which means that CLK_DAC0 shall be ready after sometime of power-on, right?
Q2: was writing Reg 0x200001100, 0x200001200 and 0x200001300 required for CLK_DAC0 output?
Q2: what 0x200001100, 0x200001200 and 0x200001300 are doing here?
Q3: should CLK_DAC0 be ready after power-on sequence done?
Q4: did DAC0_DONE signal indicate the power-on sequence done?
gd8021
Can anyone from Xilinx answer the questions ASAP?
Just want to know the minimum configuration or programming or settings for getting CLK_DAC0 out!!!
This programming sequence should be stated in the datasheet. Thanks.
