ctelfer
RFSoC RF Data Converter register description
I have read through the PG269 Zynq RFSoC RF Data Converter product guide but I cannot find documentaiton on the block registers used to control some features of the ADC/DACs (e.g. ADC threshold settings).  It seems the only desciption of these registers is provided indirectly through the Software Driver documentation.  For example, I cannot find a description of the set of registers found at 0x16000 for ADC Tile 0 Block 0.  I see the defintions in xrfdc_hw.h for the Software Driver but it would be nice to see a document which details the registers if this is available.  If anyone could point me in the right direction that would be great.
Thanks!
klumsde
The register map is not intended to be shared... Setting the thresholds is only supported via the driver
klumsde
