Requesting for xazu7evfbvb900pkg.txt file
I could not able to open xazu7evfbvb900pkg.txt file and links is https://www.xilinx.com/support/packagefiles/zuppackages/xazu7evfbvb900pkg.txt
Please share me xazu7evfbvb900pkg.txt file.
And also Kindly let me know the pin description difference between xazu7evfbvb900pkg and xczu7evfbvb900pkg.
tenzinc
Interesting, seems the link is broken. I will see what is going on and fix the issue. Please use pinout file for the commercial part # xczu7evfbvb900 as it should be the same as a workaround.
T
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
tenzinc
T
