01-17-2021 10:43 PM
A LUT6 in SLICEM can only be used as a 32 bit and not a 64bit Shift register. As I read this is due to the master/slave operation. However, I don't understand how this works. Can anybody please explain.
01-19-2021 07:28 AM
Not really. This has to do with the internal architecture of the LUT and Xilinx has not discussed the reason why in any documentation. It may be discussed in a Xilinx patent, but I haven't gone looking for it.
The only thing that is important for the user is the fact that this is the case - a LUT6 can implement a 32 but SRL.
If I had to speculate, I would guess that it is because the SRL functionality comes "for free-ish" due to reusing the mechanism that gets the configuration bits into the LUTs, which is known to be serial. My suspicion is that the configuration shift is done with Master/Slave pairs with two phase non-overlapping internal clocks - this accomplishes the shift with fewer transistors. But when acting as an SRL we don't have two phase non-overlapping clocks, so we are restricted to using every other element in the chain. But again, this is all speculation - the only thing that matters is that it is what it is (a 32 bit shift register).
Avrum
01-19-2021 06:44 AM
Hi @dharpeer
Have you looked at the CLB UG574: https://www.xilinx.com/support/documentation/user_guides/ug574-ultrascale-clb.pdf
01-19-2021 07:28 AM
Avrum
