SYSMON and MGTAVCC, MGTAVTT
I am searching ug580 and ug1085.
It appears that both PS SYSMON and PL SYSMON can monitor both PS Serdes transceiver supplies:
MGTRAVCC
MGTRAVTT
But - can either SYSMON monitor PL Serdes transceiver supplies:
MGTAVCC
MGTAVTT
Emmett
Do you have access to Vivado? I would try jumping into the SYSMON IP and see what you can and can't monitor. I agree the documentation does not make this particularly very clear in regards to the transceiver supplies. I will follow up with our documentation team to update UG580 with this info.
I just popped up the IP in one of my MPSOC projects and it looks to let me monitor all three MGT supplies. See below:
T
T
Thanks for your reply.
I wanted to kudo and accept as solution, but those options were not on the page.
When I re-customize the MpSOC, I see SYSMON in the IOU block, but it is not clickable.
I also did not find any IP in the library.
How did you get to the page you sent?
Emmett
