n_particle
Strange noise structure in ZCU111
I have been working with ZCU111 RFSoC evaluation board and now facing with strange noise problem.
It happens when I get data with lower sampling rate with using "RF Data Converter Evaluation User Interface".
The data at 2.048Gsps, there is strange structure even thouth I terminate the ADC input with 50 ohm.
However, the data at 4.096Gsps, there is no strange structure.
Of course, in FFT view, noise level in 2.048Gsps is higher than in 4.096Gsps (about 15dBFS)
I also checked this strange structure can be seen in other channles on other tiles.
And it can be erased with using decimation. (ex. There is no strange structure in the data at 4.096Gsps with 2x decimation. This effective sampling rate is 2.048Gsps.)
So, I would like to know
1. Is this noise is because of some kind of "sampling principle"?
2. If not, is this normal in RFSoC or just my board failure?
I don't have much knowledge of RF signals......
Many thanks!
Tags (3)
pthakare
Hi @n_particle
Looking at the time domain captures you have shared , it looks to me ADC callibration is not converging. What is the frequency specifications of signals you are trying to capture ?
1. To perform accurate calibration of the sub channels for gain and time skew, requires diversity of data points passing through sub channels.
2. When the ADC input frequency has a strong correlation to the sample rate, such as a common denominator, this leads to low diversity of data in interleaved   channels, or an insufficient number of unique data points for the calibration to accurately converge
The ADC callibration is documented in Product guide PG269
https://www.xilinx.com/support/documentation/ip_documentation/usp_rf_data_converter/v2_2/pg269-rf-data-converter.pdf
Reply if you have any queries, give kudos and accept as solution
pthakare
Hi @n_particle
n_particle
Thank you for replying, @pthakare.
I checked the calibration section in PG269 and noticed there is description about Dithering.
This section says that I need to disable dithering when I use the ADC at 2.048Gsps.(ZU28DR maximum sampling rate is 4.096Gsps) I completely overlooked this description.
After disabling "dither", the noise structure becomes normal.
Thank you for your help!
