02-21-2019 11:31 AM
Hello.
I have my own board with power monitor which checks under/overvoltages(OV). It can temporary switch power off on OV event. Is this safe to turn VCCINT off for 10-100 ms and then turn it on while VCCO active? I have read "Power-On/Off Power Supply Sequencing" in DS892 but not sure about my case.
Thank you.
02-21-2019 12:07 PM
Safe?
As in, does not harm the device or affect reliability?
Yes, perfectly safe. Table 1, Absolute Maximum specifications details what is safe. 0 volts is safe. Will loss of Vccint affect your system? Well, yes, as it will cause the device to reconfigure when power comes back, and depending on the device family, the IO may glitch, transistion, and so on. The device may also require more Iccint that if power is sequenced properly.
l.e.o.
02-21-2019 12:07 PM
Safe?
l.e.o.
