zhiha
The detail about the sysref_fpga clk and fpga_refclk of the zcu111 in ug1271
Here is my problem:
I'm using the zcu111, now I cannot find the detail about the sysref_fpga clk and fpga_refclk in ug1271, so I cannot write the xdc for the clock source.
Thanks for your help!
Best wishes
Zhiha
pthakare
Hi @zhiha
These clocks come from LMK PLL on the board.
The constraints associated with them are as follows
The complete xdc file for zcu111 is available here
https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation'
pthakare
Hi @zhiha
zhiha
Thanks for your help. My clock xdc is actually like what you say.
But I have got some critical warning like that, I don't know the reason, can you give me some suggestion to solve this.
klumsde
these warnings look like they are coming from some XDC for an IP rather than the top level on that manages the IO locations
pthakare
Hi @zhiha
This seems not to be related to RF clocking anymore.
Wondering if you can create new post (on implementation area) sharing your xdc to get the clarifcations around this warnings.
