Vineeth
Thermal Resistance Data of XCZU67DR
Hi Team
Can you please share the thermal resistance data and junction temperature of "XCZU67DR-2FFVE1156I"
Thanks and regards,
vineeth
tenzinc
These are usually located in UG1075 however I see it is not updated with these newer gen 3 RFSOC devices yet. Not a surprise since I see most of the data is still provided access via the lounge. I assume you know that these are obtained using JEDEC setup/parameters so they will not really be reflective of real world application. They maybe good for comparing different base device package thermal characteristic at a glance. We also provide thermal models as well which you can use to build a more realistic application of your full thermal set up and simulate with for more accurate results. I will PM resistance values for now.
T
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
