UART in PL
Hi I'm using zcu102 board and I made a UART RTL code but It doesn't work well
I made block diagram like below and simulated it.
I wondered why it isn't work well and if the protocol of my UART code is right.
You've made a UART or instantiated a standard free IP from Xilinx ?
My first guess from that terminal is the baud rate in the UART and the terminal do not agree.
Show us your code and we might be able to help more.
module uart_baud(clk, reset_n, T_clk);
  input clk, reset_n;
  output reg T_clk;
  /* insert your code */
  reg[8:0] counter;
  always@(posedge clk or negedge reset_n) begin
 if(!reset_n) begin
  counter <= 9'b0_0000_0000;
  T_clk <= 1'b0;
 end
 else begin
  if(counter == 9'b1_1011_0010) begin //1101_1001
   T_clk <= ~T_clk;
  end
  else begin
   counter <= counter + 1;
  end
 end
  end
endmodule
I thought zcu102's clock is 100MHz is it right?
module uart_trans(clk, resetn, T_clk, write_TDR, data_in, TxD, trans_done);
  input clk;
  input resetn, T_clk, write_TDR;
  input [7:0] data_in;
  output TxD;
  output trans_done;
  reg[9:0] TDR;
  reg[3:0] BitCnt;
  reg trans_done_Tclk;
  reg [1:0] state_Tclk;
  reg [1:0] state_clk;
  assign TxD = TDR[0];
  assign trans_done = (trans_done_Tclk == 1'b1 && state_clk == 1'b1) ? 1 : 0;
  always @ (posedge T_clk or negedge resetn)
  begin
 if (!resetn)
   begin
  state_Tclk <= 1'b0;
      TDR <= 10'b11_1111_1111;
  BitCnt <= 3'd0;
      trans_done_Tclk <= 1'b0;
   end
 else begin
  case(state_Tclk)
      2'b00 :
  begin
   TDR <= {1'b1,data_in,1'b0};
   BitCnt<=0;
   state_Tclk <= 1;
   trans_done_Tclk <= 0;
  end
      2'b01 :
   if (BitCnt < 7) begin
    TDR <= {2'b11,TDR[8:1]};
    BitCnt<=BitCnt+1;
   end
   else begin
    BitCnt<=BitCnt+1;
    state_Tclk <= 2'b10;
    trans_done_Tclk <= 1;
   end
  2'b10 : begin
    state_Tclk <= 2'b00;
    BitCnt<=0;
   end
  endcase
   end
  end
  always @ (posedge clk or negedge resetn)
  begin
    if (resetn == 1'b0)
      begin
        state_clk <= 2'b00;
      end
    else
 case (state_clk)
        2'b00:
         begin
   if(trans_done_Tclk) state_clk <= 1;
   else state_clk <= 0;
  end
        2'b01:
         begin
   state_clk <= 2'b10;
  end
  2'b10 : if(state_Tclk==2'b01) state_clk <= 2'b00;
      endcase
 end
endmodule
and the simulation of your uart ?
