trenz-al
UG1087 small error
AMS_PL_SYSMON
it seems the addresses for SUPPLY2 and SUPPLY3 (or its meaning) are swapped.
SUPPLY2: VCC_BRAM reads back as 1.8V what really can be true :) there would be smoke coming out, but UltraSoM+ is happily alive :)...
pratham
@trenz-al Thanks for poinintg this out. Can you please send your feedback by clicking on send feedback from the UG? This feedback goes to documentation team and owner of this UG.
-Pratham
trenz-al
Dear @pratham
I would do it, but how? Did you verify that it is possible todo what you asked?
http://www.xilinx.com/support/documentation/registers/ug1087/ug1087-zynq-ultrascale-registers.html
UG1087
where is the feedback link or button? I do not see it.
pratham
@trenz-al I didnt check. Seems HTML, i would check on this and let you know other way to send feedback
-Pratham
trenz-al
would it just be simpler you do it (forward this info to where it is needed) as talking about it so long here?
