Newbie jms
Ultra scale plus power
We are re-designing a board and repalcing a XCKU5P-3FFVB676E with a XCKU11P-3FFVE1517E. Both designs will perfom the same functions but the newer one will have a few more low speed gerneral purpose IO's added. Will the only difference in power consumption be what is shown in Table 7 of DS922?
Jim
Re: Ultra scale plus power
You need to use XPE to understand power dissipation.  The data sheet cannot help with understanding totla device power requirements.  My suggestion based on your description is:
1. Download the lastest US+ XPE from http://www.xilinx.com/power
2. Open the last checkpoint for the completed KU5P design in Vivado.  Run report_power producing a .xpe file.
3.  Import that .xpe file into US+ XPE.
4. Change the device to your new target, XCKU11P-3FFVE1517E.  Ensure that process is et to Max and temperature is set to highest expected operating junction temperature
5. Add any additional circuitry, I/O or other changes you expect for this new revision.
6. Double check the entire XPE for accuracy.
7. Analyze total power to understand if thermal design is adequate.  Look at per rail current to ensure board regulators can deliver adequate power per rail.
Hope that helps.
--  Brian
Hope that helps.
--  Brian
Newbie jms
This answered my question. Thanks!
Community Manager
Community Manager
@jms To add to Brian's reply, listing documentation that an help in case you need a bit of help using XPE or Report_Power in Vivado
XPE:
http://www.xilinx.com/video/hardware/using-the-xilinx-power-estimator.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug440-xilinx-power-estimator.pdf
Vivado Report Power:
http://www.xilinx.com/video/hardware/power-estimation-analysis-using-vivado.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug907-vivado-power-analysis-optimization.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug997-vivado-power-analysis-optimization-tutorial.pdf
- Giri
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
