trenz-al
UltraScale+ Dsiplayport: untrouted net, new BUG?
it seems that in 2015.4.1 Displayport IP core has major problem causing the GTREF clock to be unroutable, there are answer records that indicate that similar problems existed, and have been solved, but it seems that in the case of Displayport there is still as showstopper bug in 2015.4.1
or is there some trick or patch to get the clock rouiting to pass DRC ?
trenz-al
it passes bitgen with 2016.1, so the issue is solved.
athandr
Can you paste the exact error? If possible the XCI file and the project which should help reproduce this?
Anirudh
trenz-al
[Route 35-54] Net: zsys_i/displayport_0/inst/support_inst/clocking_inst/gtrefclk0_in[0] is not completely routed.
it is very simple to reproduce, just select ZU9EG as device and try to implement anything that includes Displayport IP core..
athandr
hI Trens, I am checking on this locally and will get back with the results.
Anirudh
athandr
Hi trenz,
I tested this locally with the same XCI file and the device name and do not see any such routing issues. I did this with the example design using IP Catalog and not in the IP Integrator. In any case this should not be an issues.
Please try with the example design at your end and let me know if you see failures. This was tested with 2015.4.1
Anirudh
trenz-al
well we need the IPI flow, I can try the IP catalog to see if has routing problems
I am currently trying to back-port the DisplayPort 7.0 from Vivado 2016.1 to Vivado 2015.4, well this does not to be a good idea either.. :(
trenz-al
athandr
2016.1 is not yet released. How do you have access to this version of the tool?
Anirudh
trenz-al
I have tested again on 2015.4 also, the problem was in our design, I had connected an on-chip frequency counter IP core to lnk_clk_ibufds_out pin !! This is a no-go of course, it caused unroutable error that looked like it is on the INPUT path but the problem was in the clock consumer. The link clock can only be used in general fabric using lnk_clk output in ultrascale+
I think fpr 7 series would the second direct output also have path to PL, well with ultrascale its different.
