wenhaohuang
UltraScale+ HDMI: untrouted net?
There is a problem  when I build the HDMI project for the ZCU102 board. After implemention there is a critical warning like:[Route 35-54] Net: design_1_i/vid_phy_controller_0/inst/gt_usrclk_source_inst/gtrefclk0_in[0] is not completely routed.
Is there any solution for this problem?
best regards,
florentw
Hi @wenhaohuang,
There is an example design for HDMI on the ZCU102 in vivado 2017.3. I think you might want to have a look. This could be a good starting point.
Florent
Florent
syedz
@wenhaohuang,
Can you show us the schematic of the unrouted net? Is it possible to share the post opt dcp file to debug this issue?
Check the following Answer record on debugging unrouted nets:
https://www.xilinx.com/support/answers/53854.html
--Syed
wenhaohuang
The schematic of the unrouted net like this below?
And  opt.dcp in the attachement.Thanks for your reply!
syedz
@wenhaohuang,
From the error message, the connection of GT in single quad doesn't seem to be correct. Please check Figure 2-8 at page number 36 in below UG :
https://www.xilinx.com/support/documentation/user_guides/ug576-ultrascale-gth-transceivers.pdf#page=36
Also check this Answer record: https://www.xilinx.com/support/answers/66823.html
--Syed
florentw
Hi @wenhaohuang,
Florent
Florent
wenhaohuang
 Yes, there is a example.I used the vivado 2017.3 to open the example,but it didn't work .Just now I try again and it works. Thank you very much !
florentw
Hi @wenhaohuang,
As the issue is solved could you close the thread by marking a response as solution?
Thanks and Regards,
Florent
Florent
wenhaohuang
Hi @florentw
Sorry,I  don't know  how to close the thread.Do you mean that set your response as solution ? And thank you again for your help.
florentw
Hi @wenhaohuang,
Yes set a response as solution. Thanks for doing it.
Florent
Florent
randriantsoa
I got the same errors when I tried to move the zcu102_hdmi_8b_exdes_2018_3 to zcu104 board with the appropriate xdc file (pinning modified for matching with zcu104 board).
[DRC RTSTAT-1] Unrouted nets: 2 net(s) are unrouted. The problem bus(es) and/or net(s) are hdmi_example_zcu102_i/vid_phy_controller/inst/gt_usrclk_source_inst/gtrefclk0_in[0], and hdmi_example_zcu102_i/vid_phy_controller/inst/gt_usrclk_source_inst/gtrefclk1_in[0].
I use Vivado 2018.3.
Could you help me?
Best regards,
florentw
Hi @randriantsoa
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
I would suggest you create a new topic on the appropriate board
Florent
