Visitor sthotakura
Ultrascale FPGA trasceiver power on current values
We are having the power on current values for VCCINT, VCCBRAM, VCCAUX, and VCCO power supplies in DS 892 pg.No 11. But not for MGTAVTT,MGTAVCC,MGTVCCAUX power supplies.
Could you please help me, where to get these values or how to get these values?
Community Manager
Community Manager
Re: Ultrascale FPGA trasceiver power on current values
@sthotakura You need to use Xilinx Power estimator or Vivado Report Power if you have the RTL. XPE can be downloaded from here and quicker way to get the estimate since you know your logic utilization.
Please review the below and you will be able to get the current draw on the MGT rails to be able to design your power supply.
XPE:
http://www.xilinx.com/video/hardware/using-the-xilinx-power-estimator.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug440-xilinx-power-estimator.pdf
Vivado Report Power:
http://www.xilinx.com/video/hardware/power-estimation-analysis-using-vivado.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug907-vivado-power-analysis-optimization.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug997-vivado-power-analysis-optimization-tutorial.pdf
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
hi @sthotakura,
Ultrascale Architecture has two types of transceivers, there are
  • Ultrascale GTH (16.3 Gb/s): Low power & high performance for the toughest backplanes
  • Ultrascale GTY (30.5 Gb/s): High performance for optical and backplane applications; 30G transceivers for chip-to-chip, chip-to-optics, and 28G backplanes.
GTH POWER SUPPLY
The GTH transceiver Quad requires three analog power supplies:
1. MGTAVCC at a nominal voltage level of 1.0 VDC for Ultrascale FPGAs and 0.9 VDC for Ultrascale+ FPGAs
2.MGTVCCAUX at a nominal voltage level of 1.8 VDC
3.  MGTAVTT at a nominal voltage level of 1.2 VDC.
The pins for each of these analog power supplies are tied to a plane in the package. In some packages, there are two planes (a north plane and a south plane) for each of the analog power supplies.
for more information see the ug576.
now GTY:
The GTY transceiver Quad requires three analog power supplies:
1.MGTAVCC at a nominal voltage level of 1.0 VDC for UltraScale FPGAs and 0.9 VDC for UltraScale+ FPGAs
2., MGTVCCAUX at a nominal voltage level of 1.8 VDC,
3.MGTAVTT at a nominal voltage level of 1.2 VDC.
for more information please see the ug578.
I believe I have answered your query.
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Visitor sthotakura
Hi Chandra,
Thanks for your quick response, I would like to know the current values after power on.
For example for VCCINT as per DS892[Pg.No 11]
Table:7 Power on current by a device
ICCINTMIN+ICCINT_IOMIN=>ICCINTQ+ICCINT_IOQ+2400
similarly, where can I get information for MGTAVCC, MGTAVTT, MGTVCCAUX
hi @sthotakura,
This are values that MGT need to have once you power your board .
Chandra
Chandra sekhar
Visitor sthotakura
I need MGT's quiescent and static current values once power up the FPGA.
1. This information is required to select the appropriate regulator[for MGTAVCC and MGTVCCAUX] to my design.
2. I know how much logic I am going to use for MGT's[Clocks, number of pairs etc..]
Just I need current values after power up the FPGA.
Community Manager
Community Manager
XPE:
- Giri
