quincyq2003
Ultrascale IDELAYE3 cascading four slave delay
Hello
The ug571 document only provide IDELAYE3 cascading three slave delay architecture.
I want to used IDELAYE3 cascading four slave delay.
How do i can implement ?
vuppala
Hi @quincyq2003
You can follow the same procedure which is provided in UG571 to cascade four delay elements.
Note: Make sure you are not crossing the byte boundary while cascading delay elements.
Vinay
betontalpfa
Hi @vuppala
I cannot see how can even number (four) of delay element can be used. If I continue the pattern located in the IDELAYE3 chapter of the UG571, I can cascade only odd number ofdelay elements.
Is it realy possible to connect four delay elements? I think we can connect five elements and we can set zero delay one of them.
